20 Most Recent
Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera Questions & Answers
WHAT DOES AN ERROR SAYING NOT CONNECTED MEAN
On page 59 it says:
So I guess you did put in anUSB cable, but did not connect any device. It also could be something got stuck in the USB connector in the camera. Only blow to remove any debris, because you easy could break anything inside the connector. If you see anything in the connector try to emote it.
How do I copy pictures from my camera to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
