Televison & Video Logo
Posted on Oct 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio 42", have picture for about 5 mins then screen goes black.
I have a picture when I turn on the tv but after 5 mins the screen goes black. If I turn the tv off and wait about 1 min and turn it back on, I have a picture again but then the screen goes black after 5 mins. Still have sound.
  • 2 more comments
  • Anonymous Mar 24, 2014
    tv screen goes off while watching
  • Anonymous Mar 25, 2014
    Black Screen and white light no picture or sound
  • Anonymous Mar 29, 2014
    tv turns on and shows picture for about 2 minutes or so then screen goes black if i turn tv off and back on picture does the same thing
  • Darlene Erickson
    Darlene Erickson May 31, 2014
    the power supply seems to be putting out the correct volts to plugs
Anonymous
Level 2:
Scholar:
  • Expert 155 Answers
  • Posted on Oct 26, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
155
Questions
Helped
57691
Points
374
Also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
  • 1 more comment
  • Anonymous Oct 26, 2008
    if the wires are proper then definately the problem of power transistor on the main motherboard.
    you can get the power transistor at.
    www.radioshack.com
    if u have technical knowledge you can order the part and replace.or call the technician to do it for you.
    it will be bit costly so do it carefully if try to do yourself.
    goodluck
    thanks,
    if you go into your channel map (the area in your setup menu where you can add
    or delete channels from appearing when you channel surf) the tv does NOT save
    your channel map settings once you turn your tv off. this can become EXTREMELY
    annoying if you have channels you don't want to surf through or have analog
    channels that don't come in well. i have to go to this menu every time i turn on
    the tv before i start watching, and delete all the channels i don't want to see
    before i start channel surfing. and then once i turn the tv off and turn it back
    on, you have to repeat the process again. it is sad that i have gotten extremely
    quick at doing this since it is not something you should have to deal with on a
    daily basis
    2. another function that does
    not save your settings on the tv is the delta volume setting in the sounds menu.
    if you have channels that are at different volumes, this setting is supposed to
    allow you t oadjust each channel's volume seperately so that when you surf, you
    don't come across one channel that is whisper quiet while the next channel is
    extremely loud. this is extremly apparent when switching between inputs, and
    also between analog channels and digital channels. the most annoying part about
    it not saving this feature is that once you set the delta volume and change the
    channel, the setting GETS RESET TO ZERO! it renders this feature useless if it
    does not save right when you change a channel. what is the point of this feature
    then? why not just use the regular volume control?
    3. once in a while, the tv will stop working. i have had it for
    3 months, and sometimes i change the channel and all of a sudden the tv screen
    goes black. it seems to freeze up. you can't turn it off, change the channel or
    anything like that. you can't even turn it off by pressing the power button on
    the actual tv, you have to unplug the power chord, and then plug it back in and
    turn the tv back on and then it functions normally again
  • Anonymous Feb 06, 2013
    Number 3 sounds like the same problem that I have
Anonymous
Level 2:
Scholar:
  • Expert 136 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
136
Questions
0
Helped
48163
Points
309
Its the problem in the power supply board of your tv.
    any of the IC or the capacitor has got loosed on the power supply board.remove the board and check it out.and if every thing seems proper then just cold solder whole board and it will be proper.as the soldering joints are getting loosed after some time .so cold soldering will help.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
1helpful
2answers
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
My 42in Vizio LCD has sound but no picture. Screen starts blue when it turns on then goes to black with only sound.
Make sure in the back of the TV the "picture cords" or A/V cables are properly fitted.... Hope this helps :)
2helpful
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
2helpful
2answers
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
2answers
VIZIO 42" FLATSCREEN
Turn off the closed captioning
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
