There might be some unread message in your phone, or sometimes this problem occur due to overflow of phone memory.So, during this we need to format the particular phone.Make back up all important files and do it.Tips type *#7370# when the phone is in normal mode or Select "Restore All" from the phone setting.Good luck
Thank your solution very much, but I don't know my LOCK Code. How can I get it????
Hi @Meiyan wu....please follow this link to get/generate your codehttp://www.fixya.com/support/r10146792-g...
Thank you very much! I've found my code, but the licence key for my Ultra MP3 still the problem to me. It still doesn't work. I really need my Licence key for it. Can you help me? My Imei is 353766009424754. Thanks in advance. :-)
SOURCE: When I connect my Nokia
@Anuj ..
Does your phone gets restarted frequently or only when you connect it with PC?
If it gets restarted frequently , your phone memory may be low. Move the files from phone memory to Memory card.
Hope this helps.
SOURCE: my nokia c5-00 phone is
There are two things that can be wrong here. One is worse than the other.
It could just be that the charger cord has been bent and worn to where it has a break in the wire and can not get charge to your phone.
Or your phone might have something wrong with it's charger port.
You can go to a phone store and see if they have a charger for you to try so you can figure out if it is something wrong with your charger cord or your phone. If it is your charger cord that isn't working then you will simply have to replace it. If it is your phone that isn't working, then you might ask an electronics place if they can fix it or else you might have to replace your phone.
I wish you the best of luck. Thanks for using FixYa!
SOURCE: Nokia C5-00 black screen with
1.FIRST UPDATE SOFTWARE..........................
2. CHECK THE DISPLAY
3.CHECK THE CONNECTORS OF DISPLAY
4.CHECK DISPLAY IC
SOURCE: How do i clear a
hello sheeba951,
delete the contents from the phone
>to delete sms and contacts,send sms
*12345*Delete* sms contacts
>to delete sms and contacts and pictures,send sms:
*12345*Delete*sms contacts pictures
>to delete sms and contacts and sounds,send sms:
*12345*Delete*sms contacts pictures videos sounds
>to delete sms,contacts,pictures,vidoes and sounds,send sms:
*12345*Delete*sms contacts pictures,videos and sounds
>to delete sms,emails.calendar entries and call history,send sms:
*12345*Delete*sms emailscalendar history
>to delete all the contents send sms:
*12345*Delete*all
To generate your code use this trickhttp://www.fixya.com/support/r10146792-g...
