B100 causing the reset button on plug to go off. Can the coffee maker be reset or is this a sign an electrical part went bad and will need to be replaced?
I have the same problem with the B60. It was a gift and I can't return it so I'm going to take it apart and see if there are any fuses in the machine.
It is nice template
<a rel='nofollow' href="http://www.printablecalendar2017.us/2017/08/free-yearly-printable-calendar-2018.html">free yearly printable calendar</a>
Looking for fuses will not solve the problem
triggering the reset button is an indication of over load current and that is a short
take it to an appliance repair shop for repair or junk it
SOURCE: Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
SOURCE: Keurig coffee maker causes kitchen electricity to short out.
I'm not completely certain what the problem is because it's not displaying your whole subject (it get's cut off after electricity to...). However, if it is solving the problem by moving it out of the kitchen, it's likely that the problem that the circuit is overloaded. Coffee makers have a large current draw, as do many other kitchen appliances. If you plug too many of them into the same circiut and then turn them on, you will put too high a drain on the circuit and it will cause the the current to become unreliable and then, eventually, through the braker or blow the fuse to protect the wiring in the wall (to keep it from catching fire). If this is the case, you need an electrician to run another circuit or remove some appliances from your kitchen.
SOURCE: Where can I get a replacement water reservoir for
Called the manufacture and they are sending out a replacement reseroir no charge.
Great coffee maker and GREAT customer service.
SOURCE: We had a very short power outage and had to reset
No your brewer is fried call keurig 1800 cup brew
SOURCE: I have a B60 and
One of the hoses is leaking inside... a very common problem...it can be fixed, but getting the machine apart is difficult...
here is a tip that has a picture of the machine with the covers off...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
