Viking DFUD142 Built-in Dishwasher Logo
A
Anonymous Posted on Feb 11, 2012
Viking professional dishwasher DFUD142 panel lights flashing, and cannot turn of pump, need to cut power, will not go on? worked perfectly 4 yrs. what to do? repair man did not fix.
Dishwasher pump runs when turn on, and panel lights top door not working, will not turn on, pump does not turn off, cut circut breaker. repair man said drain pluged. cleaned drain, still will not work. do we need door safety switch or do we have bad temperature sensor,or bad timer? not fixed after repair man left, need help, parts numbers, do not have owners manuals. bought 2008. help please? need solution fast.
1 Related Answer
Lloyd Carter
  • 153 Answers
  • Posted on May 12, 2011
SOURCE: viking Professional Dishwasher - dfud142
more than likely the door saftey switch is broken, check your owners manual
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 • Dishwashers
Cycle control lights flashing all at same time
are you sure you have cleaned all the water outlets as when these get blocked and the water builds up the dishwash will go into a standby mode as a sefety precaution to stop your kitchen getting flooded if it was me i would take off all water outlet pipes and use boiling water and a good cleaning fluid it only takes a little blockage and then it will cut off so clean all pipes through properly and then try again is the water going into the dish washer before it cuts off or is their no water going into it either if you post back ill have a nother look for you hope this is some help i had same prob with mine but it was different brand of washer but after cleaning all pipes inlet and outlet it worked fine and is still working now use good limescale remover cause if you live in hard water area then this is probably you problem .......................................................
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
4helpful
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a...
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
2helpful
2answers
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
3helpful
My Viking Professional VUD 141 DISHWASHER will not pump water through the spray arms
I have a viking VUD140 and there is no power cord. Can someone tell me where the power supply is suppose to go.
Dishwasher: upper tray rolls out everytime the door opens
put 2 small pieces of cardboard under the front legs until you get it where it wont roll out anymore. i had the came problem with my kenmore and it took care of it
Quote from Local Vendor
depends on what he is required to do to gain access to the control panel. if you are handy with tools and are comfortable doing the repair... buy the part and replace it yourself.
Robert
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
