My receiver used to kallow pass through with my Ps3. Now it will not. I have reset both devices to no solutions. My Ps3 works fine when directly connected to my tv. I connect all components with hdmi cables. I have used different cables, different hdmi inputs. I've connected through game/tv hdmi input on my receiver with my tv hdmi cable and everything works. Use my ps3 hdmi, no signal.
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
SOURCE: Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
SOURCE: onkyo 606 doesnt show video anymore fom ps3 over hdmi
Hi!
I had the same problem with the PS3 and the Onkyo 606.
Today I send it for repair...
Onkyo??? Never again
SOURCE: I have a onkyo TX-SR606
This is a very famous problem with Onkyo Receivers.
This latency problem is with the HDMI daughter board in the AVR is bad in the receiver.smd regulator and smd capacitors are defective.If under warranty have HDMI board replaced.
Just search in Google about Onkyo Receivers.You will get this issue has a main problem.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
