1995 Dodge Dakota Logo
Posted on Feb 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 dodge dakota truck has no oil pressure
Has oil leaks, just changed oil and filter but still no oil pressure.
raj somaiya
Level 3:
  • Dodge Master 5,370 Answers
  • Posted on Mar 03, 2012
raj somaiya
Dodge Master
Level 3:
Answers
5370
Questions
0
Helped
3571046
Points
14579
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
5 Related Answers
Anonymous
  • Posted on Sep 05, 2008
SOURCE: 1995 Dodge Dakota Pick up
go to Didgeforums.com.
I had a similiar problem, found the solution there. It was the wiring harnes on the drivers side under the hood, just above the wheel well. there are a cluster of wires in a bundle. I unpacked the bundle carefuly and sure enough the were two or three wires all coroded, had wite powder from corosion. repaired the connections and bingo. I posted details at dodgeforums.com. browse around there. I posted pictures as well. this is a common problem.
Anonymous
  • 1077 Answers
  • Posted on Jan 19, 2009
SOURCE: 1995 dodge dakota antifreeze leak
Best to use a pressure tester on the radiator to see the leak happen without the engine running.
Anonymous
  • 150 Answers
  • Posted on Feb 17, 2009
SOURCE: How do you change power steering pump on a 2004 Dodge Dakota
If the pressure hose has a hole in it you will never stop the leak because the fluid can reach 2500 psi. You will have to replace the hose. If the leak is at a fitting you can most likely replace the "o"-ring or washer . Hope this helps.
Paullycarguy
  • 35 Answers
  • Posted on Feb 26, 2009
SOURCE: '97 Dodge Dakota 5.2l oil pressure problems
How many miles? Sounds like its time for a motor rebuild. I would do a leakdown test, puts the cylinders under pressure and it is supposed to hold it for a certain amount of time. Or if you do not have access to a leak down tester, a compression tester. Sounds like the motor has quite a few miles. If you want to limp it to its death, put some thicker oil in it. 20w50.
mike raines
  • 120 Answers
  • Posted on Mar 04, 2009
SOURCE: I have an 1989 Dodge Dakota with the V-6 TBI
have you tryed to pull a code besure the plug wires are in the right place i mean fireing order
I have a 97 dodge dakota it is leaking oil from the oil filter. the seal is good and it is tight.
if u just had the oil change recently I would unscrew the filter and make sure the old oil filter rubber seal did not stick to the block when the old oil filter was removed. If there is two seals on it tight it will still leak. It happens more than you think.
1helpful
Hi I am Brasilian and I have a Dogde Dakota 1999 V6 - 3.9. I am having a problem with my car due to oil pressure. When I accelerate my car after 3500 RPM and came back to 2500 RPM with the car in moviment,...
If you haven't done so recently, change the oil and filter, if problem is still there, change the oil sending unit, if that don't cure it, then there is an oil pump problem. Doing this is easier and cheaper than having to drop the oil pan if you don't need to.
5helpful
4answers
Changed oil recently on 96 dodge dakota, 3.9l. now after driving for a few miles the check oil light comes on and gage drops down to zero. can you help with this?
Hello, please let me give you some info that will be useful to you. The engine that you speak of is notorious for developing sludge and carbon buildup. These particles are gathered up at the pickup tube screen. This is why te pressure changes, the screen gets clogged, and, when the engine is turned off, the particle fall to the bottom of the pan.
What I would do: Raise the vehicle, and make sure that the vehicle is secure. Be real careful. Next, drain the oil. Then, remove the oil pan. Inspect the pan for debris, and the pickup screen for clogs, or blockages.
I recently had one of these vehicles in for service, and I cleaned the pan 3 times, and the issue reappeared each time... then, the owner got fed up with the debris issue, and traded it in.
Thanks for visiting FixYa!
2helpful
Have 2001 dodge dakota showing low oil pressure by meter not light error code shows p done
install a new oil sending unit and change oil and filter should take care of it,oil sending unit is around the oil filter area
2answers
No vivible external oil leaks. I just need to know
It is inside the motor. So its twice as bad as your fuel pump. Have fun.
Oil leak
need a new rear seal. best left for a shop to repair as this is a hard and delicate job
2helpful
2answers
Check out your freeze plugs. They are thin metal cups that press fit into the side of the block. Use a mirror and a light to inspect while the engine is running.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
