In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. You can usually look and visually see the spot where the switch should be and if damaged. How to repair :
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. The lid switch will be attached to this portion so located it, remove the two screws that hold it in place, under the lid, and swap out with a new one. This is a cheap repair, just take your time and you'll be fine.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
The spin cycle does not go up to speed. Once the spin cycle statrs the machine spins left and right a few times then when it is time to start the fast spin it stops and the water pumps just keep on going.
Thank you.
email [email protected] for a solution
