I just bought a Casio FR-2650 second hand, and I'm having trouble getting it to work right. Initially, I could not get the paper to go into the machine, even if I tried to pull it through. It would get stuck near the center. I noticed that there was this tacky black substance that seemed to be what was causing the sticking. I eventually workded that out, and now I can load paper by pulling it through. However, it will not pull the paper through if I hit the feed button, and when I try to print anything, it will type it, but not shift the paper up. It just types over and over in the same spot. I am not convineced that it isn't missing a part. I would really like to get this thing to work
SOURCE: How do I replace the ink?
there is a little ink roller in there that should just pop out and then you can snap the new one in.
SOURCE: Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
SOURCE: casio fr-2650 plus is showing an E on the screen
Follow theses steps (from Casio Support) :
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service
SOURCE: My Casio FR-2650 Plus isn't printing in the
There is settting for the print setup for this calculator I believe if not then check the print head for build up or blockage
SOURCE: Need 2- sets of paper
Good day!!!!
please try to order it from this site:
http://www.calculatorsusa.com/calculator__parts__roll_arms.htm
if the roll arms is not fit to your calculator..please contact the number on that site...1 800 272-0272.
Hope it helps..
Thanks for using fixya..
