Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Hello Chester. I am using two inputs on this TV, component one for satellite TV and hdmi one for blue ray. No broadcast air. The ghost comes and gos on both inputs. It started after I recorded a sports broadcast on composite one to the dvr. the one and only time I used dvr. This was done via laptop streaming from the internet. Wondering about a reset, maybe a way of to disconnect dvr ? Board replacement? Hoping for some sort of a solution. I also
deleted the program and reformatted the dvr,s hard drive.
Hi Steve...
To reset the previous settings kindly try to restore factory settings..Press menu then find factory default or restore factory settings then press enter..That was the helpful procedure to determine if the problem is on the settings..I think there is something wrong with the resolution set up..
try to restore factory settings then back to me after if not help..
Hi Steve...
