Hello
Normally LCD screen will costs about 1/3rd of its whole price. You can get it replaced from Samsung Authorised service center nearby you. Never buy it and try to replace it by yoursef. Sometimes it will make you loose money. Get it repaired by the service center itself. OK.
LCD stands for Liquid Crystal Display. It is all one unit and when broken can not be repaired. The only way to fix it would be to purchase a replacement screen but that would probably cost more than replacing the whole TV. You might look for a used TV of the same model with a good screen and a bad circuit board and exchange parts but it is far easier to replace circuit boards than LCD screens so if you find a similiar model with a bad circuit board take the good board from your set to make the one with the good screen work again.
UNFORTUNATELY THIS FAULT CANT BE REPAIRED THE WHOLE LCD SCREEN NEEDS TO BE REPLACED CONTACT YOUR HOUSE AND CONTENT INSURANCE COMPANY IF IT BROKEN BY ACCIDENT THEY WILL COVER IT.
No,the LCD screen panel are broken right?The LCD screen are 90% of the tv,will cost the same as a new tv to do the replacement of the LCD screen.Now the tv,not worth as a whole tv anymore.Tv only can be salvage for electronic boards only now.
Unfortunately the only way to fix it is to replace the whole LCD panel. There is no way to fix the issue other than having someone replace the whole screen. They cost usually around $1000+ and repair shops usually charge about $200 in labor. It is usually less expensive to buy a brand new TV.
More than likely you need a new LCD. I found out the LCD on this model is a bit more sensitive than normal and will malfunction if you put too much pressure on it while sliding the phone. I have these screens in shop and replace them all the time. [email protected]
It is possible to fix but unfortunately the whole lcd panel is one unit so if it is on the inside or outside the whole thing will have to be replaced. The cost on such a thing is right around 3/4 of the price of the tv.
