Car Audio & Video Logo
Posted on Oct 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All right I'm having EXTREME problems with my car stereo. Not only have I talked to several car stereo advisers, and also mtx advisers I have also talked to Crutchfield advisors and no one has solved my problems nor explained in depth the reasons. So I'm emailing you as a last HOPE! Please help me in solving this. Ok the situation... I have the stock 07 Hyundai Tiburon; from the battery I ran one gauge wire to a 200-amp fuse. Then directly to my MTX Thunder 7801 amp, “400 Watts rms x 1 Channel @ 4 Ohms, 800 Watts rms x 1 Channel @ 2 Ohms, 1200 Watts rms x 1 Channel @ 1 Ohm”, which I purchased form Cruthchfield, which then the amp is hooked to a 15"inch Mofo Power Acoustik - Dual 2 ohm voice coil, 2600 watts peak, 1400rms. (With a 1 farad Rockford capacitor extended of the amp) So my problem then comes to when I play music, do remember everything has been thoroughly checked over several times, every connection is correct, as the music is playing my amp plays to what is thought to be normal tone, but the fuse in the amp soon blows! Thinking something is wrong I check the malignance lights nothing is wrong internally, no shorts nothing. I also had it sent in to MTX to be checked and it was sent back with a stamp of approval. No matter what kind of sub, or even the wiring of the sub, such as lowering and highering the ohms, it has been hook up every way imaginable, the fuse in the amp still blows after a couple minutes of music. The amp should and was recommended handling this sub. So over or under powering problems should not be a reason. My last resort would be the alternator in my car, from my research I have came up with the conclusion that the 07 Hyundai Tiburon some stock with a 90 amp alternator "low yes" but still should be able to drive the amp...??? Would that be the cause of my fuses constantly blowing? Another question is, I recently found out that the shell of my amp is charged with a (positive) charge, "No clue to how much positive current is running threw it," but it still has a positive charge, could that be a reason? PLEASE AND THANK YOU FOR YOUR TIME, PLEASE EMAIL ME BACK WITH YOURS AND OTHERS OPINIONS. [email protected]
  • ryangivler Oct 11, 2008
    it will take a week or so before im able to get back 2 u with the pictures, but no it will not blow any fuses at a low volume, its when it give it volume say normal volume, not extremely loud cause that just makes it blow quicker, but at a normal volume after a couples secounds of playing it some blow. Someone also told me to make sure that the positive wire wasnt touching the chassis, but the wire into the amp is wrapped in electrical tape with a hole cut so the wire connects to the input......?
    as no one can find an answer, im sadely coming to the conclusion that MTX sold me a **** AMP and now will never replace or fix it. i have returned it and they return it back to say "oh its fine" THEN Y THE **** DONT IT WORK" im starting to get bad remarks to mtx.
  • Inno Laur May 11, 2010
    So from a good source of ground (car chassis) to the outer cover on the amp you have 12V pos ? That is most definitely not good. Without actually seeing it it's really hard to figure out what's wrong. Could you possibly post some pictures of the connections at the amp, the fuse at the battery (where the 1 gauge wire connects) and your ground from the amp to the vehicle chassis?
    Do you have to crank it up before the fuse blows or does it still blow at a lower volume level?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 11, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
226
Points
0
Larger wire to amp should fix that pulling too much juice and heating filament up blowing it
Inno Laur
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Oct 11, 2008
Inno Laur
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
26068
Points
198
Don't give up yet, I'm sure we can find an answer. With car audio, as with any do it yourself project there may be just some small thing you are missing.
What is the long volume/bass control"s proper name.
the Control you are talking about is an External Bass Control also known as EBC knob you can probably find one at MTX.com or crutchfield.com or any authorized MTX dealer. Please vote and leave high marks. Thank you
Need to know how to wire my system ...I have the infinity reference series 611a I was told it was a mono block but it has two channels on the exterrior...also I have two 12 inch MTX thunder dual voice coil...
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
Why do my mtx 8100d amp keep cuting off
wrong wiring for the speakers. to low of an ohm load so amp is going into protect mode. rewire to 4 ohm stereo.
Car stereo
check your amp to see if its on high or low setting in order for it to bump it needs to be on low thats all the bass settings and you shouldnt hear the words come out of your subs
Extreme PC Gaming Headset - Echo problem
just buy a new one if symtom persist re install driver
Need proper wiring details.
This is a dual 4 ohm sub. By wiring the terminals in series (one set of + to - from one side to the other) you will have an 8 ohm sub (most folks probably don't want this). By wiring in parallel (+ to + and - to - and connect the - wire to the - terminal on your amp and the + wire to the + terminal on your amp you'll have a 2 ohm sub.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
2answers
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
