Before you change to new control box, try to go to power chair service garage who have PP1 a programmable controller. So they can find a trouble code that occur on your controller.
Regards,
mas Didiet
10-25-08
I have a Jet 3 Ultra power chair. It stopped going and I decided to see if the bgatteries were in good shape. one of them showed apox. 13 volts, but the rear one only aprox. 6 volts. Looking at the charger meter I did not see any signal of a charge with the chair connected to the 127; volts at the wall. The only thing that works, faintly, is the whistle and the control lights.
Any ideas? Thanks
Please click this link and check out what you want
http://www.medicalmobility.net/products.html
also check out this link
https://www.idaho.at4all.com/welcome.aspx
Read the information provided by ginko :
Comment by ginko, posted on Oct 04, 2008
Call (800) 794-9813 or (800) 790-4792 and enquiry about the price for a replacement control box. They answer Mon.Fri at eastern daylight time.
replace the wobble stick.
U can buy the new controller box or the required supplies from the link below:
http://www.usmedicalsupplies.com/Jet-3-Ultra-Electric-Wheelchair.htm
thanks
HI
U can get the control box from the company itself that is best for u..
For more detail see the user manual..
Thank you ..
You can order replacement parts here:
Jet 3 Ultra Power Wheelchair from US Medical Supplies
Contact them by phone for price and availability if parts are not listed on website.
If this seller does not have the part, let me know, I will give you more contacts.
If the joystick is defective, it means that the contacts on the joystic board are gone, it is not worth repairing, replace the whole part.
The seller that I posted at (800) 794-9813 should have the replacement control, and probably at less than factory price, however you can also give a call to pride mobility, and ask a replacement control from them. Here is the number 1.800.800.8586 , and the web page.
Have you checked the battery first to see if that could be the issue?
I would use a good used control Box which would work just as well as brand new one if one could be found as it only plugs into the back and fastens with some screws on the bottom side of the arm
Its got a new Battery and brand new Charger in the requested Help wanted for a solution to the power wheel chair solution
so far your answers have not solved the problem
I ALREADY KNOW ALL ANSWERS GIVEN
I DO NOT FEEL JUSTIFIED TO SAY THEY SATISFIED MY REQUEST AND
THAT I WISH TO DISCONTINUE FURTHER SUGGESTIVE AND TO PLEASE CLOSE ANY FURTHER OFFERS MADE
THANKING YOU EVER SO MUCH FOR YOUR
SUGGESTIVE ATTEMPTS ANYWAY ....
