20 Most Recent
Pride Used Mobility Jet 3 Power Wheel Chair Questions & Answers
Clicking noise on jet3 chair about every 5 feet tech guy said may need grease is there a plug on top for grease
Hi sounds like a gearbox issue, could be dry but then ask the question why every five feet, think of the gears and the amount of movement required, could be a tooth missing or damaged, is it possible to get the wheelchair on it's side to find out what motor is clicking ?
Please NOTE: take care here.... i don't suggest for one minute you do this alone, and powering the scooter while on it's side must be done with care.... just jack one side up somehow and power the chair then do the other side .... once again taking extreme care when carrying this out... you will need help...
Regards
Rob
www.gewizrepairs.co.uk
I'm borrowing a Jet 3
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Pride JET 3 Ultra power wheelchair. Problem:
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jet 3 will not turn on but when you plug charger
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
I HAVE A JET 3
Please visit-www.alldatasheet.com i have a scooter myself,glad to have helped.The site is free Colin.
I have a pride mobility wheel chair it keeps a
Please visit :-www.alldatasheet.com its free and you can download your needs as PDF Files via your Adobe Reader,i have 2 scooters myself,and i know what its like to be stranded,im glad to have hopefully helped you Colin.
