All programmes work except the 59 minute cycle. To begin with the programme doesn't always display correctly in the window and even when it does, the machine simply refuses to start. The door is closed properly and the machine works perfectly at any other programme setting so any ideas as to what the fault is and can I fix it myself (I am a competent DIYer).
SOURCE: how to use hoover ac121
normally the numbers are the same for all uk machines, if the previous washer you used had numbers on it, just remember them and use them as you would, so if a number 2 was a 90 degree boil wash them it would be the same number for all uk machines, that is my experience, or older machines had letters example letter D = non fast coloureds
SOURCE: Programme Lock
did you try to hold the button in for 5 to 10 seconds let me know if this worked?
SOURCE: hoover nextra 1200
The machine only allows a limited time for all the water to drain out before it starts spinning. If the is a blockage or obstruction in the drain hose or drain pump, the machine will not allow all the water to be pumped out and it will not spin. Check for any restriction especially under the sink/tub where the drain hose attatches to the drain spigot.
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
SOURCE: Hoover SE230 Programmer rotating
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224§ion=46246&brand=&model=SE230&path=45786,46246
