20 Most Recent De Dietrich LZ9619 Front Load Washer / Dryer Questions & Answers
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
De Dietrich... | Answered on Dec 27, 2013
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
De Dietrich... | Answered on Oct 14, 2011
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
My advice is to contact the manufacturer direct- if you have not already- at
http://www.dedietrich.co.uk/service-support-i-73.html
(or a different international URL)
John C.
De Dietrich... | Answered on Aug 10, 2011
I'm sorry to say that this is potentially very bad news. The problem you describe is quite possibly because the main bearing on the drum is worn out, allowing the inner drum to "flop about", when this happend, garments can get trapped between the inner and outer drums, causing pulls in the material and stain marks as the material is rubbed hard against the rubber gasket.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about ?£20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
De Dietrich... | Answered on Jul 28, 2011
try to read this :
http://www.de-dietrich.se/Files/Billeder/De%20Dietrich%20fotos%202012/DD%20brugervejl/Sverige/div/DLZ693W-UK-GL.pdf
De Dietrich... | Answered on Jan 24, 2015
De Dietrich LZ9619 Front Load Washer / Dryer Logo
22 questions posted
Top De Dietrich Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a De Dietrich Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • De Dietrich Washing Machines
Most Popular Question
need instruction manual 39 t find
  • Washing Machines
