SOURCE: i have white/brown and white/blue left on wiring
You can download the User Manual (including the wiring diagram), from http://www.dualav.com/mobilevideo/xdvd9101.php. Anyway the blue/white cable will be +12V, after the 9101 is switched on, and can be used to power a electronic antenna, a motorized antenna, a amp, etc. The white/brown cable can be connected to the reverse light and would automatically open the panel and switch to rear camera operation when the reverse gear is selected. The wires left on the factory harness can be anything. MAYBE the orange wire is the car-light and MAYBE the blue one powers up an antenna-amp. It should be possible to find out the function of these wires investigating the pinout of former conected equipment.
SOURCE: all the wires n the back of the diagram are all
Red and Yellow are the constant 12v and ACC12v. Grounds are black.
SOURCE: I have eonon need the reverse cam hooked up
just hooked it up with the back sight view input port on the dvd player.
SOURCE: Hi, Can you tell me
the blue/white wire is for turning on an amplifier if you are using one. if not cap the wire off as it is hot when the radio is on.
