20 Most Recent Dynex 20" Digital TV Questions & Answers
Too much red, orange and pink in the picture,
mike, mine is doing the same thing - by chance do you use
dish network? I think it's them because both of my t.v.'s are doing the same thing and at the same time...
10/11/2010 2:15:30 PM • Dynex 20"... • Answered on Oct 11, 2010
My vcr needs for the tv to be on channel 3, but I
ok well try, connect first turn on vcr...turn on tv browse channel if youd just click for the channel that the output is the vcr 50% due to weak reception then thats the channel youll manually fine tune till the perfect output of vcr comes out.
12/31/2009 3:34:10 AM • Dynex 20"... • Answered on Dec 31, 2009
Panasonic DVD player won't play DVDs on TV.
use the RCA or euroscart connectors.
8/27/2009 6:19:21 PM • Dynex 20"... • Answered on Aug 27, 2009
Thin line across the screen
The vertical control IC has failed, this is high voltage you might need a pro to do it . Julio
8/3/2009 2:14:53 AM • Dynex 20"... • Answered on Aug 03, 2009
I have dynex flat screen hdtv,need to hook up jvc
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
4/24/2009 4:15:13 AM • Dynex 20"... • Answered on Apr 24, 2009
NO PICTURE, BUT TV HAS SOLID, SLENDER,HORIZONTIAL LINE ACROSS SCREEN
Your TV has a vertical deflection failure. There are parts that have failed. This will require time to troublshoot and service.
The make you are mentioning is not a known quality brand name.
You should get an estimate before deciding to service the set. The service cost may be expensive if there is no warranty on the set.
If you decide for a new set, I would suggest staying with a quality brand name and get a service contract.
Jerry G.
2/14/2009 4:53:59 AM • Dynex 20"... • Answered on Feb 14, 2009
2answers
How do i Connect RCA VCR to Dynex 20" 480i tv
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
1/24/2009 4:23:20 PM • Dynex 20"... • Answered on Jan 24, 2009
What's TV CODE for Dynex 20 " tube tv?
http://www.dynexproducts.com/universalcontrolcodes.aspx
This is Dynex's own site for that problem. It works for over 11 different cable companies, Direct TV & Dish both included.
11/12/2008 2:16:07 PM • Dynex 20"... • Answered on Nov 12, 2008
Why doesn't my Roku Express not work on my Dynex tv, screen says not supported.
Is the Dynex a Smart TV connected to the Internet? Generally speaking, they are a budget brand
Solved: Remote won't control Dynex TV
Roku Community https://community.roku.com > Remotes > td-p Aug 28, 2020 - Solved: So I just purchased a voice remote to allow one remote for a Dynex TV in the office. I have cycled through so many brands without ... 7 answers · Top answer: All the line of sight was good. It's just that so many companies rebrand TVs that electronics ...
I have a Dynex Television. Is this compatible wit - Q&A
Best Buy https://www.bestbuy.com > site > questions > question Sep 11, 2018 - After that you need to make sure you have a wireless network so the Roku can connect. All of this takes minutes and then it will try to program ...
How To Connect Your Roku Device To Your Dynex TV
CertSimple.com https://certsimple.com > how-to-connect-your-roku-de... Nov 11, 2022 - From there, select the "Player" option and then choose the "Connect to a device" option. On the next screen, select your Dynex TV from the list ...
How to Set Up and Connect Roku to a TV: Complete Guide
wikiHow https://www.wikihow.com > Connect-Roku-to-TV 1. Connect the Roku to the TV with an HDMI cable. 2. Note the HDMI port number on the TV. 3. Turn on the Roku. 4. Turn on the TV. 5. Switch to the HDMI input on ... Videos https://www.google.com/search?q=roku+express+to+dynex+tv ..
12/15/2023 1:14:56 AM • Dynex Televison... • Answered on Dec 15, 2023
How do I set up a Auto Channel setup on my Dynex TV
It really depends on the model, but try this. Don't forget with analogue, you need an aerial of some type. .. https://www.google.com/search?q=Dynex+TV+Auto+Channel+setup ..
12/10/2023 2:00:57 AM • Dynex Televison... • Answered on Dec 10, 2023
2answers
Have F-2100 Universal TV Remote need code for Dynex Television.
But........ https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Dynex TV Remote Control Codes
Dynex Products https://www.dynexproducts.com > remote-control-code Dynex TV Remote Control Codes ; Charter DIGITAL: 0463 ; Comcast M1057: 0463, 10463, 096 ; Cox COX: 0463 ; Direct TV RC23: 10463 ; Dish Network VIP508: 720 ...
Programming Dynex TV Remote Codes [2023]
The Product Analyst https://theproductanalyst.com > Remote Codes Oct 6, 2022 - 5-Digit Remote Codes for Dynex TV · 10463 · 11463 · 11780 · 11785 · 10180 · 10178 · 10171 · 10623 ...
Remote Control Codes For Dynex TVs
directutor.com https://www.directutor.com > content > remote-control... The button will blink twice to confirm the code is stored. Dynex tv codes for universal remotes using 5 digit remote codes. 10463 11463, 11780, 11785. Dynex tv ...
codesforuniversalremotes.com https://codesforuniversalremotes.com > remote-control... Dec 19, 2015 - Remote Control Codes For Dynex TVs · 5 digit remote codes for Dynex TV 10463 11463 11780 11785 · 4 digit remote codes for Dynex TV 0490 0463 0783 ..
8/6/2023 8:20:29 PM • Dynex Televison... • Answered on Aug 06, 2023
Dynex 55 inch tv with no audio with remote and unit was off for weeks?
Reinicie el dispositivo luego descargue la aplicaci?n que dice control remoto de tv y configure todo desde el principio.
5/15/2023 10:36:15 PM • Dynex Televison... • Answered on May 15, 2023
2answers
Have a Dynex television without remote.. How can I change the channel from 2 to 3 please?
Look for manual buttons on the television. Sometimes they are on the lower edge, or on the rear edges. However, those buttons only do basic functions. All televisions need a remote. Check out the Tip I wrote in my link https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
10/19/2022 12:33:07 AM • Dynex Televison... • Answered on Oct 19, 2022
2answers
My mother has a ten year old Dynex TV that keeps turning off. It is not a smart TV.
As 10 year old off brand set like this one has lived it's life out, time for a new TV. Please don't waist money trying to repair this one
8/6/2022 7:50:02 AM • Dynex Televison... • Answered on Aug 06, 2022
Why isn't my Cox cable contour box reading my dynex 32 in tv
Hi, Please disconnect and then reconnect the 2 devices before moving forward. But you can wait 45 seconds before re-connecting the devices. If that does not work, please reference the manual for your contour box. Thank you.
6/14/2022 9:30:08 PM • Dynex Televison... • Answered on Jun 14, 2022
I have a dynex TV without the remote control the touchpad on the side of the TV where the buttons are it won't let me power it on what can I do?
Pull the mains plug and count to exactly 50 and plug it back in. This is a sort of a reset. All televisions need a remote. Just buy a new one. Buy it for the specific model. Nobody buys universal remotes any more. https://www.google.com/search?q=replacement+remote+control+for+dynex+tv ..
3/24/2022 2:34:22 AM • Dynex Televison... • Answered on Mar 24, 2022
Dynex DX-L42-10A 42" Class / 1080p / 60Hz / LCD HDTV. The image on the screen has changed to a green tint and has started to loose definition. What might be the cause and is it easily fixable?
Question edited for maker and (what it is). Question moved from Computers category. Try are Factory Reset to set the picture settings to default. If that doesn't fix it, you will need a repairer or a new one. They are a 'cheap' brand. https://www.google.com/search?q=dynamite+dx-l42-10a+reset+picture+settings ..
1/30/2022 8:10:25 PM • Dynex Televison... • Answered on Jan 30, 2022
2answers
I moved and now my remote doesn't work.
In that scenario, wrong polarity would be the only issue to cause that. Google for the television make model replacement remote Buy a copy remote.
1/26/2022 6:31:49 PM • Dynex Televison... • Answered on Jan 26, 2022
Dynex 20" Digital TV Logo
13 questions posted
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
thin line across screen
  • Televison & Video
