The note that came with the new timer says "Note! Do not forget to check the jumpers" and it also has a table and that says "Jumpers X=CUT" and the table has at least one X in each column. The new timer has a "JD" but the old timer had a space there. What do they mean by "check the jumpers"?
SOURCE: jumpers
You can only have TWO (2) Devices in IDE - Master and Slave.
For example
Cable 1 (ide channel 1)
Master - HDD
Slave - Tape Drive
Cable 2(ide channel 2)
Master - CD/DVD drive
Slave - HDD
Do you have a diffrent type of cable?
SOURCE: motherboard 277498-001 setting jumpers - help please
Visit http://www.compaq.com and select the product then download the user's manual. Such informations are usually given in the users mnual. Although Compaq is presently owned by HP, but user support is still there. ([email protected])
SOURCE: Asko clothes washer front loader
Possibly blocked filter.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
