I don't know how to change the hours or minutes on the clock in my Prizm.
Thank you
Setting the ClockIn order to set the clock, the ignition switch must be in the ACC position or in the ON position. The radio may be turned on or off.
In order to set the hour, perform the following steps:
1. Press and hold the down arrow button (HR). After approximately 5 seconds a beep will sound, and the hour will advance.2. Release the button when the correct hour appears.In order to set the minutes, perform the following steps:
1. Press and hold the up arrow button (MIN). After approximately 5 seconds a beep will sound, and the minutes will advance.2. Release the button when the correct minute appears.
