My T.V. DOES NOT respond to the remote. It's not the remote as i've tested it on my other T.V. and it works fine. The T.V. is one year old. Could the remote sensor on the T.V. be bad?
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Replacing an infrared sensor have been described here in detail. If you want more details than given, just download the service manual to your DLP tV from net. Actually there will be no need for ***. you will get a sound idea about how to repalce it from this site.
