Maxell GX-MP120 (4 pack) 8mm Tape Logo
Anonymous Posted on Nov 11, 2011
Static on playback
When I record on my sony handycam, it appears normal. on playback, the tape is jumpy & skips. There are static lines going through the tape as if it is fast forwarding or rewinding. The audio is full of static - barely able to hear the actual sounds & voices. I never had this problem before until I started using the maxell gx-mp tapes. is this a coincidence?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Nov 11, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2768125
Points
24828
When's the last time you cleaned the recorder?
1helpful
2answers
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
2answers
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Playback static
Your video heads are probably dirty. I have the same problem with mine too. If you buy a 8mm video cassette cleaner, it should work. Unless there is some other problem.
5helpful
Playback
Recording and playing a new tape worked for me too. Thanks!
Audio
it is the tape running path makes the problem and normally happens in a long run. realign the tape path by carrying to a sony service centre...
3helpful
2answers
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Horizontal bars on playback plus sometimes no recorded picture
Not a solution sorry, but just to note that I have the same problem on TRV30e. It's intermittant an relatively rare, so haven't bothered getting it fixed. Seems related to certain types of DV tapes - if I change tape the problem often goes away.
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
2helpful
2answers
Playback Problems
Ditto. Old tapes seem to be related to the problem. All I have to do is put in a new tape, play it, remove it, put the old one back in and it will play normally again. I can't explain why. I know the camera has an automatic tape detection feature and I wonder if it is at fault. Perhaps the camera has trouble detecting older tapes and the brains get scrambled. A new tape resets the detector. It's just a guess.
Top Maxell Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
