20 Most Recent Sony Handycam CCD-TRV318 Camcorder Questions & Answers
Sony CCD-TRV318 Hi-8 How do I connect it to a MAC?
you probably cannot connect you camcorder, you can just use video capture software when you play the dvd on your mac. there are 100s of free to use capture software, just google & choose the one you like.
7/11/2019 1:51:30 AM • Sony Handycam... • Answered on Jul 11, 2019
Everything works except it doesn't display any video while recording but will when playing back tape from another camera. Records audio like it's supposed to. Camera was in storage for 2 years.
Hello Howard I am thinking/sounds like that the problem is in the LCD display. How old is the camera, as it been stored in a safe location to avoid any serious damage and/or a dry location. Could possible where the display opens on the camera. May be you could find a local Sony dealer to take a look at it for you. Please let me know the out come of your camera. Ben.
1/6/2016 2:59:34 AM • Sony Handycam... • Answered on Jan 06, 2016
How to connect the Sony CCD-TRV318 to a PC with a 1394 data input
Hi
Thanks for using FixYa. You can connect the USB connector on your PC to the USB Jack on your Camcorder using the USB cable supplied with it. The USB Jack is located at the bottom front left side of Camcorder which is covered with a flap and can be opened downwards. USB port on the PC is located in front and the back of the PC through which you can connect it with the Camcorder. You can also use Memory Stick.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
11/23/2014 8:00:10 AM • Sony Handycam... • Answered on Nov 23, 2014
Where is the reset button on the sony 560x camera?
I often process the postproduction in Adobe Premiere Pro CS3. But when I was to put Sony XAVC to it, I became astonished because I find XAVC is not compatible to Adobe Premiere Pro CS3 which is very wired. I don't understand why my AVCHD camcorder will output files which can not be edited in video editing software. I tired many converters and they all fail to handle the conversion of Sony XAVC to MOV. Finally, I find Aunsoft iMedia Converter for Mac which perfectly solve my problems. ... Learn more about it: http://www.auncam.com/aunsoft-imedia-converter-for-mac
9/1/2014 3:17:42 AM • Sony Handycam... • Answered on Sep 01, 2014
Why wont sony ccd-trv318 not play sound after cleaning?
You should only clean heads using liquid cleaner , never dry tape if video works ok afterwards but still no internal sound could be circuit breakdown
8/30/2014 1:01:39 PM • Sony Handycam... • Answered on Aug 30, 2014
Why wont sony ccd-trv318 play sound after cleaning
You may had it converted. Maybe after the conversion, all will be okay! Recommend you a nice converter: Aunsoft MTS/M2TS Converter http://www.auncam.com/aunsoft-mtsm2ts-converter
8/29/2014 7:50:03 AM • Sony Handycam... • Answered on Aug 29, 2014
0answers
How to use pinnacle 14 studio with sony cam tvr-318
You will need to have an i-Link cable, also known as a IEEE 1394 cable, which is a four pin to four pin cable. That will hooked to the DV output from your camera to the DV input on your computer, if so equipped. Also there is a cable with a four pin i-Link to USB cable which I use my self on my system to import DV from my camera to the edit program. Hope that this is helpful to you.
11/28/2013 12:21:21 PM • Sony Handycam... • Answered on Nov 28, 2013
Whats 2/10 in decimal form?
the answer is .2
3/21/2012 1:43:20 AM • Sony Handycam... • Answered on Mar 21, 2012
My camera beeps and flashes
The "C" is part of an error code as are the numbers that follow it. This indicates where the problem has occured. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
8/19/2011 5:09:59 PM • Sony Handycam... • Answered on Aug 19, 2011
My steady shot ccd trv318
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
6/13/2011 1:17:58 PM • Sony Handycam... • Answered on Jun 13, 2011
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
4/19/2011 6:59:19 PM • Sony Handycam... • Answered on Apr 19, 2011
Sony Handycam CCD-TRV318 Camcorder Logo
110 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
camera beeps flashes
  • Video Cameras
