20 Most Recent
Maxell CD-R 80 Minute 700MB Media Recordable CD 100 PACK (Spindle) Questions & Answers
Cant open pictures on CD-R
Take the cd back to the PC that burned it and make sure the session has closed. Open a picture to see if works. If the session IS closed then you need to have software for viewing pictures updated.
I recieved a CD with my xrays on it from a doctor
i think you will need to create a folder in my pictures then copy the files into this and then you should be able to see them ,failing which download VLC player as this great programme will also display difficult to open or funny files that media or fax viewer cannot or will not do without paying for a programme
When I put the CD
You don't mention what device we're talking about. Blank media must SAY "CD Audio" on them.
I recorded something on the CD, and it can not be
If you 'recorded' it on a CD music recorder it needs to be finalized first. CD-R's are Write Once Read Many. You can't delete from them after the fact. Refer to the manual for the creating machine.
if you go over the recomended space on a cd and it burns neway it will make the cd unreadable because it couldnt complete the finalization process reburn it on your pc with less tracks.
I have a tosiba computer,
Put the disc into your disc drive and then go into my computer. Click on the drive and see if it will read the disc. You might need to install Windows Picture and Fax Viewer to see them. Try the Microsoft website for it.
How many pictures can be put on a 700md disc
It depends on the size in MB or KB of each picture. Seven for a 100MB pictures! But many are only 500KB, two will make 1MB. So you would be talking about 1400 pictures at 500KB.
My computerwill not read my
Go into my computer or computer > right click on the cd/dvd rw drive > select properties > go to the recording tab on top > ensure that the Enable CD recording on this device box is checked.
Why do some of the
parrottrack,
The problem can only be either a software or a hardware issue. First try the software as its most likely the problem. Download a good known virus free burning software; Express Burn has a good trial copy. If you make a CD with the new software and it works, it was the software, if it you have the same results then its a hardware issue. First try cleaning the players lens, if that does not work the player has failed.
-Chris
My disk cd-R cant burn any songs
I suggest you look at the file format that you are saving your songs as. It might be that you are saving them at too high a quailty than what you need. Have a look at the disc you have done see what the file is and it's size.
Cd is not showing up on xbox 360 as playable.
try changing the format of whatever it is. if it is a game, then try it on another xbox. if it works then its the xboxs fault. if the CD still doesnt work, then you might wanna get a different game. still if it isnt a game and its a mp3 or soemthing, then look for formats that the 360 supports
I tried to burn my kodak pictures with it and it
There are different grades of cd media. Maxwell is usually a pretty good grade. That said, there are a few things that could cause this. Your drive may be malfunctioning, this could be a bad batch of cd's, or the software you are using to burn disks us having issues with the device drives for the Drive.
The first and most easiest way to troubleshoot this is to try media from somewhere else. If you can use different media and you have no problems, then you have a bad batch of CDs. If it still malfunctions, then you have a bad drive or bad device drivers. You can delete your drive from the device manager and let windows reload it when you reboot. I doubt that i the problem takes little effort to test. Last, you may need to clean your drive. There are inexpensive CD drive cleaning disks available. If all that doesn't work, then you most likely have a bad drive and will have to replace it. Very simple to do. After replacing it, Windows will see it when you turn the power back on.
