SOURCE: cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
SOURCE: Cuisinart CUI DGB-300BK... just recently started
Beeping: Push the cover to the grinder down as far as possible. If that doesn't stop the beeping, clean out that hole with a toothpick.
SOURCE: cuisinart cod-4000 powers up no brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
I do have a manual, but there is nothing like this in the troubleshooting. To add to the original post, I've been trying to work it everyday. It always just starts beeping the first time and keeps beeping for a few minutes. Then it stops and if you keep trying it will start for you eventually.
