20 Most Recent Cuisinart Coffeemakers Questions & Answers
you can try CLR and hope for good results .
Cuisinart... | Answered on Jan 03, 2018
It can be done, but it's not for the fainthearted. Simplest: Put tape over the hole above the "clean" buton to the left of the control panel. This will muffle the beeper, which is a piezoelectric disk located behind the hole. Most effective (Your mileage may vary.): 1) Unplug the machine. take out the filter cone, Set aside the pot. 2) Pop the plastic covers off the two top screws. Unscrew them, set them aside in a container 3) Use a flat-blade screwdriver. Insert it into the two slots at the top back and lever up to pry off the lid at its hinges. slide it off the hinged spigot tube, ans set it aside. 4) Use the flat-bladed screwdriver to pry the top back of the outer case off the two tabs of the top plastic insert part which extend aroudn to the two top screws, freeing the back part of the top insert so that it can then be levered upward. 5) Now, carefully lever up the top plastic insert at the two slots here you prviously pried off the hinged top. What's resisting the upward pressure is a press-fit of the black downtube, which feeds the hinged spigot tube, into the lower part of the hot-water feed. It should pop free, exposing the upper electonics module which is attached to a ribbon cable. The ribbon is held into the case by some white gorilla snot (silicone adhesive). The electronics module is held to the outer case by two screws. 6) Remove the two screws that hold the electronics module to the case. Twist the electronics module around so that you have acces to the four screws on the back. 7) Remove the four screws on the back, and lift off the back. You should now see the backside of a gree circuit board, held in place by one screw. 8) Remove that one screw. Now pry at the edge of the green circuit board to lift it away from the front control panel. You should now see the pizoelectric beeper module, a round can with a hole in its middle located behind that hole I mentioned earlier above the "clean" button. It's soldered onto the circuit board by its two leads. 9) Do you have a soldering iron handy? If so, melt the solder that holds the two leads of the piezoelectric module, lift it off the board, and throw it away. If not, first use diagonal cutters (****) to clip the leads off as flush as possible with the backside of the circuit board, then drill through the circuit board at the leads, so that the piezoelectric module pops free. Throw it away. 10) Now reverse the disassembly process and put the coffemaker back together. 11) Smoke test! Plug it into the electrical outlet. Does it still turn on when you press the brew button? If so, good. If not, go buy a new coffeemaker. 12) Water test. Put about 1 cup of water in and run a brew cycle. does it work OK? No leaks from the bottom of the coffeemaker. If so, good. Enjoy the lack of beeps. 13) Brew a pot of coffee.
Cuisinart... | Answered on Jan 08, 2017
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Cuisinart... | Answered on Nov 23, 2013
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Cuisinart... | Answered on Jun 23, 2013
You can get them at www.cuisinart.com or by calling Cuisinart
Cuisinart... | Answered on Aug 14, 2012
Cuisinart will get you the right caraffe - that model was specific to Sam's/Costco/ BJ's, and the stores do not carry them.
Cuisinart Coffeemakers Logo
94 questions posted
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Cuisinart Coffee Makers & Espresso...
  • Cuisinart Coffee Makers & Espresso...
Most Popular Question
cuisinart grind brew dcc 490
  • Coffee Makers & Espresso Machines
