Was your machine working fine? If so, WHY did you do an update? Updates are never a guarantee and fraught with many issues - U only update when there is a valid reason and it is absolutely necessary - then you cross your fingers and risk it!
U have learned the hard way and now all you can do is attempt to undue what you did. U can try a system repair of your OS since the system restore did not do the trick. And if the repair does not work, and you do not have a backup of your drive, you will have to wipe the drive and reload everything. Have fun and good luck!
SOURCE: Windows XP SP3 platform with single Delta 66.
Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
Testimonial: "Thanks for the quick response and good info, it was very helpful."
