KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
A
Anonymous Posted on May 27, 2017
How do you take off a microwave door and put a new one on?
I have a kitchenaid microwave KHMS155LSS-0 door to install to replace the old door that has a cracked handle and plastic pieces cracked and falling off. I need help in taking the old door off and putting the new one on. The part department sold me the door and told me I would be able to install it. Now that I have it a new person in from the same company is telling me I need a service technician to come do it for me for $120+ Can you help walk me through the door removal and door replacement?
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on May 28, 2017
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4481831
Points
21747
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 01, 2009
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Dec 04, 2009
SOURCE: microwave model KHMS155LSS-3 turns self on
I had the same problem with the same model of KitchenAid Microwave. KitchenAid customer service will act like they never heard of the problem, although if you google it, you will find that this is a very common problem. Ask to be transferred to the safety department. After more than 6 months of complaining and several repair attempts (they replaced control panel and switches), KitchenAid finally gave me a full refund. This is a serious safety defect for which they have no fix. The product needs to be recalled, and I am willing to testify that KitchenAid was criminally negligent when this product finally causes a house fire and possibly serious injury or death.
Anonymous
  • 572 Answers
  • Posted on Feb 06, 2010
SOURCE: MY KITCHENAIDE MODEL KHMS155LSS-4 TURNS ON & LOCKS ITSElF
faulty keypad
I am in search of a Kitchenaid KHMS155LSS-2 microwave door
Question edited for clarity
The glass, inner door,and outer door can be purchased spearately or they sell the complete door.
https://www.kitchenaidparts.com/Shop-For-Parts/a6b121d653453-x646f6f72/Door-Model-KHMS155LSS2-Kitchenaid-Microwave-Parts
However;
For more information on replacing this part, please call 866-698-2538 for assistance in scheduling a service appointment.
This place says the complete door is obsolete.
https://www.partselect.ca/Models/KHMS155LSS2/Parts/?pSearchTerm=door&start=1
It is probably time to replace it
https://www.google.com/search?q=KHMS155LSS-2+microwave+door
How do I replace kitchenaid microwave door handle?
This is not a fun one if you take a putty knife and go in between the outer door and frame you can release the outer door cover hears the catch over time the door frame becomes brittle so there is a 50/50 chance the frame will break trying to separate it
1helpful
Where can I buy a new handle to my KA KHMS155LSS-0?
A replacement handle can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part numbers are as follows:
8169737 - White
8169738 - Black
8169739 - Bisquit
8184264 - Stainless
When ordering, make sure you use the appropriate part number to match the color you have. All these sites offer competitive pricing, so shop and compare.
If you need assistance in how to replace the door handle, the following link explains how:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If you have questions, or need additional assistance, please post back and let me know. I hope this helps you.
I have a kichenaid microwave#khms155lss-4 my son put a stainless steel bowl in it and i dosen't work help its only 3 years old
It's most likely a blown magnetron thermostat, but you should also check the fuse and the oven cavity thermostat.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the thermostats for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
1helpful
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
1helpful
Rattling coming from top grill on Kitchenaid microwave
the gril at the top (above the door) usually comes off with a couple of screws or just pulls off .. on some you have to take the cabinet apart ..... inside you might find a flat filter put in at a slant .. its often a grease and smell filter that contains activated charcoal .. when it gets clogged then it can rattle around as air tries to get around it .. you can replace it or just leave it out ..
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
