Dictaphone 3740 Desktop Cassette Transcriber / Recorder Logo
Anonymous Posted on Oct 10, 2011
Dictaphone intermittently shuts off while recording.
Dictation Mall
Level 2:
  • Expert 145 Answers
  • Posted on Oct 14, 2011
Dictation Mall
Expert
Level 2:
Answers
145
Questions
0
Helped
54599
Points
173
The power jack sometimes comes loose on this model. With the power on, wiggle the jack. If it powers off, then it needs to be resoldered. Service can be done by dictationmall if needed.
My dictaphone 1243 wont record sound
I'm sorry to hear that your Dictaphone 1243 is experiencing difficulties with recording sound. Here are a few troubleshooting steps you can try to resolve the issue:
1. Check the microphone: Ensure that the microphone is not obstructed or damaged. Clean any debris or dust that may be affecting its functionality.
2. Volume settings: Verify that the volume is not set too low or muted. Adjust the volume settings accordingly.
3. Batteries: If your Dictaphone 1243 operates on batteries, make sure they are charged or replace them with fresh batteries. Insufficient power can affect the device's performance.
4. Recording mode: Confirm that you have selected the correct recording mode. Some devices have different recording options, such as voice activation or manual recording. Ensure you have chosen the appropriate mode for your needs.
5. Storage space: Check if there is sufficient storage space available on your device. If the memory is full, it may prevent further recordings. Delete unnecessary files or transfer them to another storage device to free up space.
6. Reset or firmware update: If the above steps do not resolve the issue, you may consider performing a reset on your Dictaphone 1243. Consult the device's manual or contact the manufacturer's support for instructions on how to reset the device. Additionally, you could check if there are any firmware updates available for your device and apply them if necessary.
If none of these steps help to resolve the problem, it might be best to reach out to the manufacturer's support team or consider taking the device to a professional technician for further assistance.
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Will Dictaphone Write work in Windows 7?
Hello yes it is. Walkabout Transfer Software, version 1.5.2, is required for the WA5220 portable. Backwards-compatible with WA5210/5215(DS) portables. Windows 7 compatible. For Dictaphone Digital portables and Trancription kits you can go to http://www.tvps.com/Departments/Digital-Dictation/Digital-Portable-Recorders/Dictaphone.aspx?sortorder=4&page=1
1helpful
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Top Dictaphone Audio Players & Recorders Experts
NOEL
NOEL
diyfixtool phonefix
diyfixtool phonefix
Adviser101
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
