Alesis Sr 16 Stereo Drum Machine Logo
Anonymous Posted on May 14, 2017
Hi, just got an alesis sr-16 drum machine and actually its my boyfreind who can program it somewhat, i read only the first 18 pg.s in the reference manual 2 times myself, i think it sounds kinda complex. it would be great if you can tell me what steps for my boyfreind to take so he can program in 2 kick drums on a drum set and also set the snare drum so it can trigger as fast as the machine is capable of doing. thanx in advance, i was glad to see this link that allows me to ask a question from someone who can help out!
5 Related Answers
Anonymous
  • Posted on Jul 13, 2009
SOURCE: need foot switch for this machine.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function.
I bought mine from my local music shop for £15 ea
Fred Yearian
  • 5603 Answers
  • Posted on Dec 27, 2009
SOURCE: cannot transfer beats from alesis sr16 to alesis
The sync signal that is sent on the MIDI cable is actually a "clock" of something like 96 ticks per measure. This is the "MIDI sync clock". This is a single byte FF hex.
The beats themselves are not sent. The firing of the individual percussions should be.
Anonymous
  • 74 Answers
  • Posted on May 06, 2010
SOURCE: how do i dump midi user patterns from alesis sr 16
you may well have to go via a third unit, a computer or laptop to store the data then send it back to the other machine.
Fred Yearian
  • 5603 Answers
  • Posted on Mar 10, 2011
SOURCE: I'm trying to use the pads of my Yamaha DTXplorer
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Mar 12, 2011
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
1helpful
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
I have a alesis sr 18 with a quick start guide that is not very clear on setting user programs to match to my music.The problem I've been haveing is when I try to create programs the issue is getting past...
Hello there Ken, i can help you with this unit but i need more information as you know this thing is huge it can do a lot . so do you want help on how to setup RECORDING PATTERNS or CREATING DRUM SETS and so its a very fun tool to have .
Let me know and lets get Started
Sr-16 drum machine need part
The pot is PROBABLY an audio taper so check the suffix on the old one.
Many pots you can find at Digikey.com or Mouser.com.
You MAY have to cut the shaft length
For an exact replacement you will probably have to go to Alesis.
4.7 K is NOT a standard value for pots. 5K ohms is.
How do i dump midi user patterns from alesis sr 16 to alesis sr18 drum machine thru midi cable
Cannot transfer beats from alesis sr16 to alesis sr 18 thru midi cable. Please advise.
I need program settings for my sr 16
For most Alesis drum machines the best way to get programming is to find an identical unit and clone/transfer from it. Try a music store that sells Alesis.
A second possibility is to go to website(s) and download a SYSEX file to transfer via MIDI to the unit.
I need to find the instuction manual for an Alesis SR-16 drum machine. I was told that it is available for free on line. Where?
Go to alesis.com/sr16 the reference manuel, program chart etc. are all there. I just went there to double checkit and it is there.
Alesissr 18 drum machine lcd does not display
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Top Alesis Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Alesis Music Expert? Answer questions, earn points and help others
