Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
SOURCE: what cord do I use where to upload photos onto computer
The Panasonic Lumix digital camera you bought comes with an USB cable. Try to find the data cable port in the sides of your cam and insert. The other end must also go to your PCs USB port. Even without an installer, the PC will be able to detect your camera as a removable drive. Explore your Camera as a removable drive and extract your desired picture files into your PC of laptop.
SOURCE: COMMUNICATION ERROR WHEN UPLOADING?
my camera did this after lending my camera and cord to somone else to upload pictures onto their computer, and then when i tried on my own it wouldnt let me.
all i had to do though was take the memory card out and put it back in.
SOURCE: Trouble uploading photos from my camera.
you need the driver for your camera so that the computer can read
SOURCE: Can i upload photos through the USB cord?
use the alternative. Obtain a card reader and insert it into the reader which in turn is connected to the USB port
Generally the USB should be recognised, but there is quite often this problem due to different levels of USB ( 1 and 2)
SOURCE: sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
