SOURCE: Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
