SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
SOURCE: How can I fix a Fisher double tape deck that won't
If you are getting no power then you need first to check the internal fuse. It might have simply blown without anything having gone (if your lucky). Some models use a fusable resistor, often an odd looking resistor with PC markings as: FR (100) unlike normal ones that have R100.
Check to see if the power switch is broken, then look around at the power section on the PC board. Suspect anything on a heat sink, look for signs of burning and damage. If you have a muti-meter carefully check to see if anything is getting power.
SOURCE: I need a complet set
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
SOURCE: I need a diagram that
A simple search engine found the procedure...
http://www.youtube.com/watch?v=Q-TPh_PxkvU
