20 Most Recent
Pioneer CT-W205R Single Dual Cassette Deck Questions & Answers
Where can I get replacement belts?
They are hard to find but try the MCM Electronics catalog. You will need to know the dimensions of the belt (i.e. width, length...).
Good Luck !
Why one tape at deck A won"t come out. it stock inside unit
There are lots of causes to this. For example the mechanism has jammed. The tape has become entangled in the capstan or elsewhere. Plastic damage causing the mechanism to not move back to the eject position. Some decks have a powered eject that is faulty. Broken spring, or one that has fell off.
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Faulty CT-W450R
The rubber belts inside the unit have gotten stiff and slippery. All belts should be replaced. That will resolve the problem.
Dan
Faulty Pioneer CT-W450R
Check to see if their is any voltage going to the motors. If not look at the power supply. Electrolytic Capacitors dry up when not being used and can cause faults like that.
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps:
Turn off the receiver.
Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display.
Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" .
Press the "Enter" button on the front panel to confirm .
If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
