then read the #1 "hit" that your search has found -- your answer is right there -- you do not need to "click" the hyperlink attached to that FIRST hit to get your answer.
If your owner's manual does not address it, it's not meant to be user-accessed, so you will need to remove the outer cover to access and change the bulb.
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Open the top of the range. I believe there are a couple of spring clips in the front between the range top and the top of the door. Not sure on the Maytag. However, when you get the lid up, (it should be hinged at the back), set the burner pieces back on. (These burner pieces HAVE to be there or you'll just have a blowtorch pointing up!) You'll see that going to every burner there is a tube to carry the gas. on the side of every tube there will be an adjustable, sliding air vent. They are usually held in position by a set screw. Loosen the set screw. Light the burner and carefully slide the vent closed or open to adjust how much air is being brought into the mix. If the flame is way too high and or orange in color....you have too much air. You want as much flame as possible on high without the flame being orange or white-ish. Once you get the flame the way you like it, tighten the set screw back. Hope this helps.
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
