You'll need to remove the glass from the fireplace, but not before turning off the pilot light. Then mix a 50/50 solution of White Vinegar & Water. Using a sponge soaked in the solution and partially wrung out, clean the glass on both sides using the solution & sponge. Reapply as necessary until the glass is clean. Dry thoroughly with paper towels, before reinstalling the glass.
The heat stain is not really a heat stain. It's left over residue, from when someone used commercial glass cleaner to clean the glass. The white stain is from the ammonia in the cleaner.
Hope this helps you and thanks for choosing FixYa.
