1) Water heater is tripping breaker. Sounds like a short in water heater or bad breaker.
Open following link for troubleshoot walk-thru.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) If you have 2-element tank-type water heater, then water heater is 240Volt.
Dual-Element tanks are usually wired for non-simultaneous operation.
Only one element is turned ON at one time.
http://waterheatertimer.org/How-it-works.html
3) Some special order water heaters and water heaters that are rewired for specific reason can be simultaneous. Both elements could be ON at same time. This would be evident by 50 amp 240Volt circuit breaker and 8 gauge wire to heater, or two separate 30 amp breakers and two wires going to water heater.
4) Add a comment for more help.
5) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
