20 Most Recent Reliance & 40 Gal Mobile Home Water Heater Questions & Answers
Where is Temp. Control located on the Water Heater??????
If it's gas the control usually is at the bottom of the tank where the gas line comes in. If it's electric there should be a little trap door either at the top or bottom and the heat control is behind that door. The door is usually held in place with a screw There is a little dial with numbers you can turn up or down. There are electrical wires that you should not touch as well.
12/17/2014 4:41:29 PM • Reliance & 40... • Answered on Dec 17, 2014
How do I light the pilot
1) Open following link to identify type of gas control and read printed 'how-to-light-water-heater' instructions for each different gas control valve:http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent2) Same printed instructions should appear on side of tank by gas control valve, and inside product manual.3) Add a comment March 2013 and describe gas control valve. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/13/2013 4:09:14 AM • Reliance & 40... • Answered on Mar 13, 2013
No hot water from hot
IT SOUNDS LIKE YOU HAVE A BURNT OUT HEATING ELEMENT YOU PROBABLY HAVE TWO IN THIS UNIT CH YOUR CERKET BREAKER FIRST IF OK DRAIN THE UNIT TURN BREAKER OFF RE MOVE ELEMENTS THAY ARE BEHIND THE COVERS THAY HAVE PHILIP'S SCREWS TAKE THEM TO LOWS OR HOME DEPOT MATCH WITH NEW ONES PUT THE NEW ONES IN FILL THE UNIT WITH WATER OPEN A WATER TAP LET RUN TILL ALL THE AIR IS OUT THEN TURN THE POWER BACK ON HOPE THIS HELPS GOOD LUCK BOB
4/25/2011 4:01:43 AM • Reliance & 40... • Answered on Apr 25, 2011
What is the puk code
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
3/15/2011 11:34:17 AM • Reliance & 40... • Answered on Mar 15, 2011
How can i get PUK
You posted under Reliance water heaters, so question comes to hardware section.
Re-post question under cell phones.
2/15/2011 11:09:46 PM • Reliance & 40... • Answered on Feb 15, 2011
High operating cost. Element has 1/2 inch hard
I think your problem is the buildup, which would cause your elements to work much harder trying to heat the water - especially if you have well water as opposed to chlorinated city water, although city water still has calcium, etc. in it.. Add a whole house filter to your water line where it comes into your dwelling - there are a myriad of elements available at varying microns to catch the calcium
and other contaminants. These filters normally need changed every 3 months - I would check your after a month to see what it is catching. These whole house filter systems are not expensive - check out your local hardware or plumbing store, I'm sure they can guide you to the proper set up ( after you verify what they say through some online research) . Better safe than sorry !!
p.s.there should be 2 elements in your water heater - 1 above and 1 below, so after you've installed your filter change both elements - I'm sure you'll find they last a lot longer!! Also - before you cut off water to your home for the install, fill up a clean 5 gallon bucket and RINSE the filter element , then turn off the water supply to your water heater to prevent a loss of prime and water hammer to the pipes.
11/10/2010 5:35:20 AM • Reliance & 40... • Answered on Nov 10, 2010
Waht is the PUK code for reliance mobile sim
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
11/2/2010 10:25:53 AM • Reliance & 40... • Answered on Nov 02, 2010
Water is warm
Warm water is a result of and element gone out and more than likely top element is gone out. Best thing is to replace both element's because they are not exspensive and if you replace just one it will work the other one harder and eventually go out.
Just a little information if the bottom element goes out it will give you a burst of real hot water then get cold. If top element goes out it will give you warm water then get cold.
9/27/2010 2:16:57 AM • Reliance & 40... • Answered on Sep 27, 2010
My water heater is leaking from the bottom is
Hello It is new tank time.There is no repair for that.Don't wait for it to let go!They only last so long.
9/15/2010 1:55:20 PM • Reliance & 40... • Answered on Sep 15, 2010
I want to find out who's number is this
934 is not an area code that is in service. If you are getting a caller ID with that area code you will need to talk to your phone provider to find out why.
7/9/2010 12:18:51 PM • Reliance & 40... • Answered on Jul 09, 2010
No hot water
You may have 2 elements. Make sure both circuit breakers are on.If the heater is old it may be plugged up with sediment. Flush out via valve on bottom. If no water comes out or it is very rusty keep running till clear. If it does not help probably time for a new heater.
6/7/2010 12:11:32 AM • Reliance & 40... • Answered on Jun 07, 2010
CARVER CASCADE 2
Hello .. when an electric water heater only gets warm, it is usually the thermostats. I would replace the thermostats, make notes where the wires are connected .. make sure after replacing that the back of the thermostat is flat against the metal of the tank.
Please Vote !!
5/14/2010 3:42:55 AM • Reliance & 40... • Answered on May 14, 2010
2answers
Carver cascade 2 No water at all comes out of the
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
4/18/2010 2:33:19 PM • Reliance & 40... • Answered on Apr 18, 2010
No stop tap. cold water coming through cold taps
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
6/24/2009 6:10:16 PM • Reliance & 40... • Answered on Jun 24, 2009
No water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
6/21/2009 8:43:52 PM • Reliance & 40... • Answered on Jun 21, 2009
2answers
Are all 25VS FV sensors equivalent?
I personally wouldn't replace a safety device (placed there by lawyers, lawsuits and the all knowing government) with anything other than OEM. While it's very likely that one manufacturers flammable vapor sensor may interchange on another brand of tank, I think it's highly unlikely that EVERY manufacturers sensor will work on every other brand of tank
10/15/2022 9:09:47 PM • Reliance Water... • Answered on Oct 15, 2022
How do I drain my hot water tank that has no drain valve?
Shut off water open lowest drian/ tap off water will run off there .It will take the pressure off
11/14/2021 10:39:53 PM • Reliance Water... • Answered on Nov 14, 2021
I have a Reliance water heater that pilot won't light. Model6-30-nomt 400 Need some troubleshooting ideas
check gas flow of tube if ok replace pilot generator
12/19/2020 7:29:46 AM • Reliance Water... • Answered on Dec 19, 2020
A.O. Smith Water Heater. What does error code of 991 indicate?
Here you are Dorothy AO Smith code 991 Solution for error code 991 Check the gas type of the water heater. Inspect the environment around the water heater. ... Check if there is grease and/or dirt in the burner (Part #101) and the fan motor (Part #103), especially if the water heater has been installed in a contaminated area.
Error code '991' for type ATI-110C-N by AO Smith. Cause and ...
More help here, but you probably need a service call, especially if it is a gas water heater. https://www.google.com/search?q=error+code+of+991 ..
11/30/2020 8:35:13 PM • Reliance Water... • Answered on Nov 30, 2020
Reliance & 40 Gal Mobile Home Water Heater  Logo
Popular Tags
20 questions posted
Top Reliance Water Heaters Experts
john h
Paul Carew
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Reliance Water Heaters
Most Popular Question
water warm
  • Water Heaters
