Technics SL-1210 Turntable Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moved my technics from downstairs where they were working to my bedroom in the loft. When I re-connected everything the sound was way too low. Even the sound on the headphones is terrible. Currently have them connected to the speakers on my hi-fi which plays waaaaay louder when a cd is in but not when connected to my technics. I think I may have set them up wrong...can you help me?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Sep 12, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2768162
Points
24828
Turntables only plug into PHONO.
1helpful
My tv in the loft doesnt work at all well it runs from a booster on thevfirst floor then through a bedroom with a splitter then up to my bedroom in the loft
TV signals are funny things. A signal that is perceived as being weak might not be at all because unless great care (and some luck) and some good materials are used longish cable runs can gather so much interference the tv set behaves as if the signal is weak.
A splitter will halve the signal.
Ideally a booster should be positioned close to the aerial so it is amplifying a cleaner signal and not amplifying interference. A masthead signal booster is the best option for a single or double downlead.
For a rooftop aerial and multiple downleads, first the aerial must be a high gain type in the frequency band used in your area. The shortest downlead possible would then feed into a signal booster (in the loft) with multiple outlets so each room or tv set has an exclusive downlead that hasn't been interfered with or split.
Each downlead should be low-loss double-wrapped coaxial cable with the best quality plugs you can find.
You might find it easier to obtain an exclusive aerial for your bedroom tv.
You could try replacing the aerial cable to your room with low-loss cable and get rid of the splitter and booster and replace with a quality booster with two outlets...
How do I assemble the Powell z bedroom loft bed?
find the Powell customer service number and call them for the manual
I cant get a picture in my bedroom got a tv and didi box, i am in shared accomadation but wen i take tv downstairs it works on the outside ariel and also so does the didi box am at wits end please can some...
have you tried an active booster/amplifier, indoor aerials are very bad on digital signals. the best way is to fit a booster in the loft and run a new cable into the room, but it may be difficult in shared accommodation, do it when every one is out :) hope this helps.
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
I moved our computyer from downstairs to upstairs.
Power supply is bad,,
You can try to unplug the main motherboard plug, then plug back in,, It should last as long as it stays pluged into the wall.
Keep it pluged in when you do this,,
1helpful
LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
Sharp flat screen no sound after moving it from downstairs to up
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U. My understanding is that a surround sound system would bypass the problematic part of the sound board which is why yours worked in your basement.
3answers
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
