20 Most Recent
HP Compaq Presario SR1410NX PC Desktop Questions & Answers
I installed a wireless USB
You don't say what OS you are using but for Windows 10
Right click on the internet logo in the notification area
Select "Open network and internet settings"
Select "Wi-Fi" from list on the left
Ensure Wi-Fi is switched on and also check available networks.
3/3/2018 12:24:23 PM •
HP Compaq...
Answered
on Mar 03, 2018
Need drivers for video controller
Your motherboard is a asus ASUS P4GV-LA, with a Intel 845GV Graphics
You can download video driver on this page:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Embedded+Components+and+Flash+Memory&ProductLine=Embedded+Chipsets&ProductProduct=Intel%C2%AE+845+Chipset+Family
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
2/27/2011 1:57:43 PM •
HP Compaq...
Answered
on Feb 27, 2011
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
