SOURCE: Could not start LeapFrog Connect with tagq
If you are using a Windows machine, try the troubleshooting steps outlined here:
http://lfccontent.leapfrog.com/cs/docs/Could_Not_Start_LeapFrog_Connect_Error.pdf
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
SOURCE: I boaght 2 Leapster Explorers.
This issue is most probably being caused by an intermittent disconnection from the requesting host (your computer) to the file file server (website). You can either use a download manager to download your files so even if the "request" disconnects, the download manager can manage to resume the download once the connection gets back.
You can get a free download manager here: FlashGet Download Link
Click on "download the latest version" on the right hand side and install the software. Download the LeapFrog application using FlashGet.
Hope this works for you.
SOURCE: Installed Leapfrog Connect for my
I'm having the same problem! Did you ever get it to work?
-Linda
