20 Most Recent LeapFrog Leapster Explorer Learning Experience Questions & Answers
How can I reset Leapster GS
LeapFrog... | Answered on Jun 21, 2018
Not really sure about the batteries but have heard some companies put extra batteries so if two batteries go dead in the middle of a program you have back ups.
LeapFrog... | Answered on Sep 29, 2017
To open the battery compartments firmly press down on the arrows with your thumbs and push it out. You should feel the cover unlatching as you firmly press down and out.
LeapFrog... | Answered on Dec 26, 2014
Try taking out the batteries and running an eraser over the contacts. One other thing plug it in with the batteries installed and try turning it on. After it comes on then unplug and see if works. Also make sure you are using the right kind of batteries. I had to use alkaline to get our to work.
LeapFrog... | Answered on Jul 06, 2014
On the back there is a big silver screw. Open it and the back comes off. The batteries go there be sure you get the right ones. I believe they have to be alkaline.
LeapFrog... | Answered on Jun 15, 2014
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
LeapFrog... | Answered on Aug 25, 2013
you must restart your pc and reconnect it.
LeapFrog... | Answered on Jun 02, 2013
hi, i too have the same problem...did you eventually figure it out? because it is extremely frustrating
LeapFrog... | Answered on Jan 01, 2013
LeapFrog Leapster Explorer Learning Experience Logo
46 questions posted
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
Keith Koene
Crystal Walters
Crystal Walters
Level 1 Expert
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
View Most Popular
LeapFrog Toys
  • LeapFrog Toys
Most Popular Question
volume button doesnt work
  • Toys
