Canon Optura Pi Mini DV Digital Camcorder Logo
Joe Noren Posted on Apr 27, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Optura Pi is eating tapes
At 45 minutes into a recording, the camcorder ate the tape. The unit was running on AC power, the tape was new. Placing another new tape into the camera results in an eject tape message and the tape leader is eaten by the camera. The camera likewise ate a new cleaning cassette (dry type)
Anonymous
Level 2:
Champion:
  • Expert 277 Answers
  • Posted on Apr 30, 2006
Anonymous
Expert
Level 2:
Champion:
Answers
277
Questions
Helped
171586
Points
362
Hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
2answers
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
1helpful
Canon Optura Pi Mini DV Digital Camcorder. The metal compartment holding the tape won't open. Battery is charged, everything else works. Cannot remove the tape.
Tape mechanism malfunctions can be due to many factors. A bad gear is the most likely cause and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Optura Pi Mini DV Digital Camcorder: I connected to AC and recharged, turned on and got...
yes i think; if you can find a good tech he should be able to make the mechanism alignement and clean out debris could be in the mechanism but he can charge you more because its as been open..
and clean the mode switch all that can be done with out parts replacing beleive me i know! because i fix a lot of camera and cam corder
hope that will help you..
regards Alan...
2answers
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Canon Optura 40 playback - only get blue screen - no image, no sound
    Try a cleaning tape. Buy a good quality cleaning tape (Panasonic makes one) and remember: cleaning tapes are abrasive so don't overuse it! Overuse can result in the need to replace the rotating drum assy in the camcorder. I'll bet a cleaning tape takes care of your problem.
    2answers
    Tape eating
    unit need to be cleaned or have parts replaced if they got bad enough.
    only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
    Canon Optura Pi Mini DV Camcorder
    you can use software to capture it on your computer and burn a DVD, or there are services that will do it for you for a reasonable price. Windows Movie maker will do it if you can load it on your computer. If you are not familiar with the technology then just use one of the services. Most large cities have them or you can us an online service.
    Top Canon Video Cameras Experts
    NOEL
    NOEL
    john h
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
