Game Boy Advance SP - Charging Light Won't Display
If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
Troubleshooting Steps:
Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
SOURCE: My gamboy advance sp won't charge. The battery
I had the same problem. It was a solder connection in the charger socket. I tried to fix it but made it worse. I ended up having to switch the battery with a charged one from another GameBoy. That's how I was able to keep using it.
