20 Most Recent Olympus SP-310 Digital Camera Questions & Answers
manual
Battery Uses
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
11/1/2012 11:38:11 AM • Olympus SP-310... • Answered on Nov 01, 2012
How do you delete images on the Olympus sp 310
The delete button is above the LCD monitor on the back of the camera, the second button from the right, marked with a trashcan. While viewing the picture you want to delete, press this button. The camera will prompt to make sure you want to delete the picture.
4/19/2012 4:55:51 PM • Olympus SP-310... • Answered on Apr 19, 2012
Where is the delete button
4/19/2012 4:54:26 PM • Olympus SP-310... • Answered on Apr 19, 2012
My pictures for my Olympus sp-310 will no longer download from the camera to the computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
1/18/2012 9:57:20 PM • Olympus SP-310... • Answered on Jan 18, 2012
SP-310 Worked fine for a
Replace the battery(s). Rechargables don't last forever.
1/7/2011 11:52:58 PM • Olympus SP-310... • Answered on Jan 07, 2011
Camera fell and the lens
THERE WOULD BE INTERNAL PROBLEM, SO MY ADVICE TO U IS , JUST REPAIR IT FROM SERVICE CENTER OR CAMERA SHOP
12/15/2010 6:51:46 PM • Olympus SP-310... • Answered on Dec 15, 2010
The SP-310 shows a Zoom Error on the screen, and
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 5:23:23 PM • Olympus SP-310... • Answered on Sep 27, 2010
Looking for free manual download for olympus
http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1187&fl=8
You can download the manual from that link.
Thank you and enjoy!
Lee
8/2/2010 5:16:42 PM • Olympus SP-310... • Answered on Aug 02, 2010
Zoom error lens will not come out, problaby stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/29/2010 12:43:15 PM • Olympus SP-310... • Answered on Jun 29, 2010
Olympus - SP-310 camera. Has broken LCD screen.
I Have a sp310 camera... It has a problem with optical zoom. Do you like to sell me your camera ou can you buy my camera?
2/20/2010 3:19:13 AM • Olympus SP-310... • Answered on Feb 20, 2010
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
2/11/2010 10:33:38 PM • Olympus SP-310... • Answered on Feb 11, 2010
My Olympus SP-310 has wavy lines in all the pictures. I found a solution before on the internet - it recommended changing one of the settings. However, I can't remember what it was, and I can't find t
If the camera was working fine "before" you made a setting change, try going into the setting and selecting "factory Default" That may correct the setting you may have experimented with. And, make sure your battery is fully charged first!
1/27/2010 11:35:17 PM • Olympus SP-310... • Answered on Jan 27, 2010
My olympus sp-310 camera shows empty battery but I
Are you sure you put them in with the correct polarity facing the right way. Its a common mistake.
Also try a "known" set of batteries just to make sure.
Good luck
1/21/2010 1:13:59 AM • Olympus SP-310... • Answered on Jan 21, 2010
Dropped Olympus SP-310 in water for 2 seconds.
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
1/14/2010 8:22:37 AM • Olympus SP-310... • Answered on Jan 14, 2010
When I turn the camera on, the view finder is
Sounds like a bad CCD sensor. I've seen the same problem in several brands of digital cameras (Canon & Sony). Better off replacing rather than repairing.
11/6/2009 1:23:20 PM • Olympus SP-310... • Answered on Nov 06, 2009
My olynpus camera sp-310 shows battery empty when
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
11/4/2009 1:37:52 PM • Olympus SP-310... • Answered on Nov 04, 2009
Suddenly for no apparent reason Windows XP fails
Please try another USB port in computer.
Hook camera in another available USB port in computer. Hope Windows XP will recognize it and problem will be solved.
Thanks.
10/1/2009 12:26:30 PM • Olympus SP-310... • Answered on Oct 01, 2009
Olympus SP-310 Digital Camera Logo
Popular Tags
44 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
zoom error lens will not come out
  • Cameras
