SOURCE: How do you get the dryer to actually work?
That button with the 1/2 on it and then the time dial works and it sounds as if it is washing your clothes, but it is actually drying the clothes but heats up water in order to do it. It is kind of insane actually but it does work and that is the way to do it. Do you know if there is a place to clean a lint filter? Is there a lint filter somewhere?
SOURCE: Instruction Manual
it can be found here dont think thats the full model number but
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
SOURCE: Whirlpool washing machine does not work after move
you can check the harness under the control panel and make sure it is not loose from the move.
this is just the first step, so if it is not the problem let me know and I will help you figure it out.
Mike
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified.
SOURCE: I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
