Konica Minolta bizhub C450P Laser Printer Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot print Labels
I have set up a page of Labels to print. But the printer ( Konica Minolta C250/C250P PCL ) gives an error when I try to print. Are there maybe certain settings needed to be set on the printer to allow label Printing. I tried setting the paper size to A4 but the printer reads it as K16.
  • deborahd781 Sep 11, 2008
    Hi There
    Thanks for your solution. I have tried using the bypass tray, and also changing the paper type settings. It still does not work though.
    Any further idea's you may have, will be hreatly appreciated.
    Thank You
    Hi There
    Thank You
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on Sep 10, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
Helped
198029
Points
292
The printer is setting the size from the position of the tray guides.
If it is reading it as K16 then that is the closest size to the paper you have loaded. The device will oook at the tray and then set it to the closest match this is the function of the Auto size feature.
Try measuring the paper and entering it as a custom size instead. Mimic the setting through the driver of course.
Run it through the bypass tray and be sure to specify the stock type/weight for proper printing.
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I am trying to print labels on the Konica Minolta bizhub 250 from the bypass tray and my labels are printing in landscape on my label sheet
Its not in the copier. Its on whatever program your printing from. Try playing with the settings. Don't forget, you can use regular paper until you figure out your correct orientations.
Why can I print a test page out but with regular printing it jams and gives c-1182 error
Finisher motor issue, remove the finisher/and unplug does it work?
what are you printing are you using staple or hole punch try printing single sheet of paper.
How to do a colour test print for konica minolta bizhub c250? The test print just comes out black and white
Press utility/counter.
Click on user settings.
Click on printer settings.
Click on Demo page/Test page print. Click on it and press Start.
Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
When I print a PDF the first page comes out in miniture format teh following pages are OK. I have Windows Vista 64 bits, Toshiba laptop Satellite model
Try to use the update the driver to the latest version or to use the PCL driver if you're currently are using PS driver and viceversa.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Copying
In the driver there are "copy protect" and "Watermark" options.
See if these are on.
3answers
Cannot scan documents on Konica C250/C250P
Hi, If it is set up as a network printer, then go to administrator settings & check the IP address of the machine.
3helpful
2answers
Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
