Once the matrix is created you can use the reciprocal key to get the inverse.
I hope you will not hold against me if I showed the whole porocess. (No reflexion on your or anybody's abilities to create a matrix. Just trying to be helpful to more people.)
Press Menu to display icons.
Press 1 or use Arrows to highlight Run/Mat.Press EXE
Press the F1 key to activate the Mat TAB.
While a matrix label is higlighted press F3:Dim to enter the dimensions.
Matrix must be squarehow do i find the - k24674_131.jpgimg src="/uploads/images/k24674_131.jpg" alt="k24674_131.jpg" class="h_mi" />
Press EXE after entering the last element.
Then press EXIT to return to the Run/Mat Screen.
In Run/Mat screen press the OPTN key. Press F1 to enter the Mat identifier
followed by [ALPHA] A (if the matrix you created is stored in A)
At this point the screen displays Mat A.
Any of the continuations of the command shown below will yield the inverse matrix.
The minus sign you see in the 2nd and 3rd commands below is the how do i find the - k24674_133.jpgbogus 2X2 matrix I entered, the result is as follows.
Notice that even if inside the answer matrix the elements are displayed as decimals, the
values you will see at the bottom are exact fractions.
Thank you!
