Ctm HS 890 4 Wheel Heavy Duty Power Scooter Logo
Posted on Aug 16, 2011
My scooter wont go and the status light is flashing green 5 times would you know what is wrong
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Nov 06, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
1684
Points
5
Hi, there is a fault finder at the back of the manual, 5 flashes means the drive motor is not coonected, check that the freewheel lever at the back of the scooter is in drive then turn off and on again with the key, hope this helps. Bill
Luis Navarro
Level 1:
Habit-Forming:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 31, 2016
Luis Navarro
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
12093
Points
84
Turn OFF unit. Locate D/N lever on back of unit (remove rear tail lid cover). Select Drive position (down). Turn on unit once gain. If problem persist, replace clutch assembly.
Pride go go travel scooter green light flashing constantly when charging, never goes off until unplugged
hi Dawn, if the light is flashing all of the time however if the scooter okay in that it does a fair distance etc, i would say there is a issue with the status circuit in the controller.
Regards
1helpful
Continuous green flashing light
a continuous green flashing status light with no pause means battery voltage low , if there is a pause count how many flashes before a pause, the controller telling you what the fault is ..
Regards
Rob
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
2answers
Green light flashing rapidly and scooter wont move
Hi, Could have the Brand and model name please ?
Regards
Rob
www.gewizrepairs.co.uk
Light flashing on mobility scooter
Hi check if the free wheel lever is in drive ...cheers
Light flashes 5 times on rascal
Mine was doing that the most likely reason is your lever located in the back of the scooter is probably in neutral. Mine would have everything brand new batteries all the lights everything was working except it wouldn't go and that's the reason the lever was in neutral. They will have a diagram showing you which one is in drive and neutral. Mine had to be pushed all the way down to be in drive once I've done that it worked perfect. Look for a lever with a colored handle and make sure it is in drive. That is most likely the problem
1helpful
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
5helpful
3answers
Need manual for craftmatic scooter
Hi. How many flashes between the pauses? Let me know and I can tell you what is wrong with it. Neil.
Top Ctm Health & Beauty Experts
john h
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
