20 Most Recent
Kymco Midi XL 8mph Mobility Scooter with Free Delivery Questions & Answers
Kymco midi xls juddering after dropping battery gauge says plenty of charge then suddenly stopped and green light flashed twice
Quite a common problem with that scooter , check the brake after about 10 minutes use , carefully place your hand around the brake but beware : it can get hot , and if that the case it's not releasing fully etc, fiction is causing the brake to heat up, don't get me wrong, it will get warm but not hot to touch ..
Brushes again need to be checked , do they come out without resistance, if no , they appear to drag then you got carbon built up or problem brushes.. clean or replace.. and you need to careful remove the carbon otherwise it create a problem with new brushes, one way is to carefully places a small screwdriver and run it down the corners of the brush holder but be careful the commutator surface is soft so can scratch easily..
Regards
Rob
gewzirepairs.co.uk
Continuous green flashing light
a continuous green flashing status light with no pause means battery voltage low , if there is a pause count how many flashes before a pause, the controller telling you what the fault is ..
Regards
Rob
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
